VR series2
im blonde?
VR Commodore S2
Hi, i hav to change rocker cover gaskets, just not sure if becoz theyre plastic do i lube wif oil or still use gasket goo??
social
Ute Finatic
South Aus
2012 VE Thunder
hey mate, i believe that you would be lining the rocker cover grooves with some red grease i think its called high temp bearing grease, do not use gasket glue. this will give a nice added sealing to the gasket too. So basically remove the rocker covers, clean thoroughly, then get the grease and put a nice layer of it in the actual gasket groove, then apply the gasket into the groove, wipe off any grease that has pushed out and then bolt her back on.
