Have i installed all correct parts for the crusie control to work. For some reason it wont turn on... but i do get a click from the bcm when i hit on... also nothing is coming up on the cluster like CRS or ON. I have installed. *New BCM and from a VR Clubsport *Module and bracket in engine bay *Brake and clutch switch *Stalk for cruise All the plug were there i just connected them. Is there a relay under dash or under bonnet that i might be missing... Cheers..
I think the computer plays a part in this and having a manual ecm it wont let you enable cruise control.
You could try splicing and running a white wire from the cruise module (under hood) straight to the violet/white coming from the speed sensor (on the gear box)....again spliced as well. Good Luck. Edit: actually according the wiring diagram you already have one running to the speed sensor from the module (green wire) connect that to white.
You also need a relay for the fuse/relay panel under the steering wheel. Note- this is on VS....I presume VR would be identical.
BCM Change Not Needed! Hi, The cruise control is independent of the BCM, so you did not have to change the BCM. Cheers.
have u had the cruise actiuvated with a scan tool for your BCM? and have u installed the bulbs in the dash cluster ?
first problem maybe that the crs light bulb is blown. 2nd, make sure things like the switches are ok and adjusted right and your brake light bulbs arnt blown. And i think there is a relay under the dash somwhere i beleive that may need installing.
