Vr stalling
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vpcalais5.0, Jan 16, 2011.
  1. vpcalais5.0
    vpcalais5.0 New Member
    vp calais
    Hey guys can u please help me out with a problem my Vr starts perfectly fine runs perfectly then after 30 seconds it drops idle and stalls I've replaced the fuel filter and pump but it's got the same problem I can also here a weird noise which is coming from the back injector or fuel pressure regulator witch sounds like water escaping into air so was thinking can a faulty injector cause this
  2. justbad4you
    justbad4you IF YOR NOT A HOLDEN
    MELBOURNE S/E BAYSIDE
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    First up Id do an error code check to see if any error codes are showing up.
