VR to VT brake issue
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by snakemann53, Mar 29, 2013.
  1. snakemann53
    snakemann53 New Member
    Yamba
    VT Commodore
    anyone out there had problems with VR to VT brake conversion ?t
    I have changed the front hubs & calipers , changed vacuum booster from VS & master cylinder , changed the resviour from a VT & done a complete
    fluid change (full bleed from left rear to front right) & I still have soft pedal & warning light on the dash any help would be appreciated.
    Thanks in advance.
  2. sxi ss
    sxi ss Member
    New Zealand
    vr ss
    Did you put a vt master cylinder in? Abs or not I had problems with mine turned out to be air trapped in abs pump
  3. snakemann53
    Yamba
    VT Commodore
    Helps if you read the the post I put a VS master cylinder with a vt resivour on top of that.
  4. two-bit
    two-bit old enough to mang better
    VS S series II
    you need a vt booster/master cyclinder with a vn-vs fluid res on top
