paz_guy
- Aug 4, 2015
- 12
- 0
- 0
- Location
- south east victoria
- lots but here for my VR
Hey all, ages ago i asked about swapping the auto in my vr v6 s2 sedan, with one from a vs s2 (4hdd to 7hdd) as i had a parts car with a good auto and couldnt afford another trans.
Well i finally put it in on the weekend,
Swapped the internal loom in the trans with the 4hdd one, and did the solenoid mod i was linked too, so the torque converter would lock up, filled it up to the correct level with nulon semi synthetic atf, fitted a new filter and the bush thing that holds it in and after starting the car and warming it up i have discovered that i only have two forward gears. (im pretty sure its 2nd and 4th)
Dont have a cel on or anything and reverse works fine.
Anyone know what it might be?
I have been told by the previous owner of the car the trans is from that it sometimes started in second if it was in drive, but would start in 1st if selected, so is it a solenoid issue or have i not done something internally i was supposed to or?
Thanks in advance
Thanks in advance
