leavz
- Aug 17, 2014
- 113
- 25
- 18
- Age
- 29
- Location
- Geraldton
- Vr Commodore
getting solvent pop is a direct result of either wrong application (applied too heavy or not flashed between coats) or too much reducer in the product.... you can get it with clear coats too.
I didn't really put much info into my previous post just thought i should add that first my bad.
Yeah that is the main reasons, although i was told a certain way to harden the paint i used (deltron ppg) I was told to use, First coat fast harder, Then second coat medium, Last coat slow.
Since i'm not a god at painting (yet ) I decided to go fast 1st fast 2nd medium last coat to reduce my chance at getting runs in case i put it on to heavy using slow hardener
Doing this worked fine on everything besides the bonnet, Idk maybe i thought at the time i would put it on heavier since it was a flat surface and it would run.
Well boy i got a nice finish at the time but the next morning did i get a surprise.
Now that's the reason i got it in the bonnet, I got a little bit through out the car it can buff out its not serious just specs on the guards ect.
Now i'm not blaming the product, BUT we've had some solvent poping problems with deltron direct gloss. We've even had a rep tell us that they know it's easy to get solvent pop and its a problem they're trying to fix.
People take the piss out of ppg abbreviating it as "piss poor gloss" ect but i think its good i've just got to get use to it.
I was by myself after work or on weekends painting so i didn't really have some one there to ask questions, i usually ask them the next working day.
I was told by the head painter he never really uses fast hardener for direct gloss for this reason (especially if you bake it)
Now that's the reason i used the clear, of course it can get solvent pop but we know from experience it's ALOT less chance using clear then direct gloss and i didnt want to take that chance,
Ppg is expensive and i didnt really want to go again with dg and have a chance at getting the same result.
