VR v6 all 6 spark plugs carboned
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by pete30nz, Apr 21, 2020.
  1. pete30nz
    pete30nz Active Member
    Christchurch, NewZealand
    1994 Vr berlina 3.8 v6 , 1996 VS executive 3.8 v6
    Hi people
    Spare cas, spare dfi and coil packs set replaced. New spark leads. Spark plugs and oxygen sensor replaced new about 1000kms or less ago.
    Was doing some work on the car, had the car running for short times and a couple of road tests for no further than 1km.
    Car was at home and started running on less cylinders. I checked and cleaned spark plugs and the oxygen sensor which were all black.
    I do have new valley gaskets to replace in the next few days if all goes well. Would valley gaskets be a symptom?
    What else should i check people?
    Pete
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Might be a faulty O2 sensor. I had a brand new one that was faulty from factory.
  3. pete30nz
    Cheers for your reply losh1971, I guess I'll Google how to check oxygen sensor with multi meter?
    Pete
    losh1971 likes this.
  4. losh1971
    North Tas
    VR Ute V6
    I think you hit them with a map torch and test the resistance with different heats applied.
  5. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    While they still shouldn't foul up too noticeably, short tests while the car is cold aren't a real good indicator as the ECU will be dumping more fuel than usual into the engine to get it to temp. You really need to look at them after a drive where the car has been at operating temp for (IDK) like 10 or 15 minutes at a minimum maybe.
    Does it run right now? The missing is likely to have caused them to foul up if it's injecting fuel and not combusting, then it intermittently combusts when there's heaps of fuel in the chamber which means the mix is rich fouling the plugs. What's the part number on the spark plugs?
  6. pete30nz
    Hi rjk,
    The plug part number is ngkr bpr6efs 15
    I'll clean the plugs and the oxygen sensor again shortly and take it for a drive.
    I'm guessing it's the fouling that's making the car start missing /running rough.
    I'm sure if I went to start it now that itit will run, but it would be running rough
    Pete
  7. _R_J_K_
    Zenki S14
    A lot of the time it's a bit of viscous a cycle. The plugs foul for some reason (leaky injector, combustion issues, misfire), then in turn the fouing makes the initial problem worse via more misfire or whatever.
    In response to your initial post, valley typically gaskets won't do this, usually they just leak oil into the coolant when they go. Are all the plugs fouled or just one side? VN-VR all use bank injection so if the plugs are all fouled on one side it's kind of telling. Other places I'd start looking are around injectors and the fuel pressure regulator, possibly the map sensor, also busted coolant temp sensor is one that would cause a lot of issues like this..
  8. pete30nz
    It's all 6 spark plugs. I'll take a photo of the plugs soon when I get to them.
    I could try another spare set of injectors.
    How to clean the map sensor?
    I have a recollection that my iat sensor could be faulty maybe?
    I'll check the ECU temp sensor under the alternator also, I think I have a spare some where.
    Pete
  9. _R_J_K_
    Zenki S14
    Given it's all 6 plugs, super unlikely to be injectors themselves. Trace the wiring loom for them back and see if they're frayed anywhere though. MAP is usually just a total replacement, you can't really clean them like you can with a MAF (MAP isn't a really common failure though, just something to be aware of).
    Have you pulled any codes from the car?
  10. pete30nz
    Hey,
    I bridged the pins and only get code 12 which is a pass.
    About to go pull the plugs shortly and check the oxy sensor
  11. pete30nz
    Here are the spark plugs I just pulled, smells a bit gassy or oily - can't decide.
    Will do oxy sensor tomorrow
  12. pete30nz
    Hey, I found this in another thread, not to sure if its my cause, but some thing to check the seals of.
    : if there is oil on the threads , may be rocker covers leaking a bit of oil and leaking into the recess in cylinder head where the spark plugs screw in . if the threads are dry and the tips of the plugs are oily , then you may have mechanical problems , worn piston rings , valve stem seals , too much oil in sump .....etc .
    Any other input welcome
    Pete
  13. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    With oil on the thread...If it's leaking from the rocker cover, you can generally see a line of oil, running from the base of the rocker cover to the spark plug hole....If you can't see this line, the issue is internal....worn valve stem seals (which is generally the issue) or worn piston rings...
    pete30nz likes this.
  14. pete30nz
    Hi VC, thanks for the reply.
    So I'm guessing all the valve stem seals wear down at the same time.
    What would I need to do to replace these.
    Edit: I found out how to just now
    Cheers Pete
  15. losh1971
    North Tas
    VR Ute V6
    Sometimes the guides wear, which doesn't help either. Some cars don't always have valve stem seals if the guides are still nice and tight. I rebuilt an old 75 engine years ago and it never had seals. The guides were pretty fucked though and it burnt oil even after rings and a hone. But I didn't want to spend money on a Repco change over head, so slapped it back on.
    Glazed bores will cause oil burn as well.
  16. pete30nz
    I'm hoping its some thing small like valve stem seals. Do these engines have valve guides as well. I'm eager to learn, have pulled my old VR v6 engine down, but all I've done internal work wise is valleys, balance shaft and hydraulic lifters.
    Pete
  17. losh1971
    North Tas
    VR Ute V6
    Eco is pretty similar in a lot of ways to the Buick. It will have guides. The valves wouldn't stay in place otherwise. I'm pretty sure you can change the valve stem seals without removing the heads. You might be able to check the guides at the same time, but it's heads off to replace them.
  18. pete30nz
    Yes they look similar. But still haven't done any internals on any engine apart from the VR engine
  19. losh1971
    North Tas
    VR Ute V6
    Internals are reasonably similar. They improved some aspects of the V6 when they went to the Eco.
  20. losh1971
    North Tas
    VR Ute V6
    I have an idea that the Buick heads will actually bolt on to an Eco but that would be as far as you would get.
