Yeah so you have a column shift like me. I still don't know why you would want to put a VY switch when the switches are easy to overhaul? I might be wrong but it sounds like a bit of mucking around to fit a VY switch when column switches are already set up and you don't need to add anything to make it work. On my VR it would a heaps of mucking around to swap the column switch even with a VR floor shift one. Not having a go BTW. I'm just trying to get my head around it, as I'm confused why you change the switch to something else?? I could probably understand if you have broken the pull wire or something, that would be some mucking around to repair.
