Vr v6 auto won't start.
redrose
qld
VR Executive v6
Hi just wondering if any one can help me please. My vr wont start I turn the key and nothing the lights work intrument panel lights up. The starter motor did make a clicking sound once. otherwise nothing not even the fuel pump. It did come up with error 31 and 12.
My key is old prob origanal and the button is missing only used the key manually.
If any one has any ideas I would appreciate any input
thank you
p.s Happy New year to every one on just commodores.
redrose
qld
VR Executive v6
We put my sons new battery in and same nothing.
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
code 31 is Theft Deterent signal, which if your keyhead battery is close to flat then wont return a signal to turn the immobilizer off when trying to start, it should still start but with a 1second delay, if the starter motor clicked then keyhead isn't your problem. If the fuel pump didn't prime check the fuse for it in the engine bay.
redrose
qld
VR Executive v6
ok thanks I will check the fuse. the nobby bit on the key is worn I was wondering if this is the problem.
The1
QLD
www.eyeit.org
VS V6 Berlina Auto
if the keyhead is completely dead then leaving in the ignition at on position for 1hr from memory it should start after that.
redrose
qld
VR Executive v6
my husband just tried to lock the car and the key wouldnt work the central locking he had to lock each door individually. So would that mean it is the key? Thanks for the input.
LS1FUN
Confused with life..
Black Holden VS S-Pack
I had the same problem with my key a couple of weeks ago. Wouldn't work at all, turned out to be the battery. Needed a new one!
redrose
qld
VR Executive v6
Hi i have replaced the key with a new one but still wont go. put new battery in just get clicking in the fuse box in engine bay. the doors wont lock or unlock checked fuses under dash. there was a blown fuse for fuel pump changed that. Help please.
