vr v6 dies when accelerating
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by fatboyvk, Aug 29, 2012.
  1. fatboyvk
    fatboyvk New Member
    taihape
    1995 vr commodore
    ok so i have had my commy about 6 months. about a month ago it run the big ends. i have since swaped the engine out for a second hand one. got it running but it it wouldnt idle some times and died when ever you would touch the gas after 30 seconds ish of running and check engine light was on and wouldnt change gear good. so had the codes read came up low voltage on tps. swapped that for the old 1. now its running good changes mint and check engine light gone out. but when ever you dump the gas it dies. any help would be much appreciated
  2. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Try changing your iac
  3. FstStig
    FstStig Diagnostician
    Central Coast, NSW
    2010 VE SV6
    Sounds like your Fuel Pump might be on its way out. Someone else has had a similar problem where it couldn't keep up with the fuel delivery at high RPM, but would be fine at low or idle.
  4. F l a k
    F l a k Member
    Wagga Wagga, NSW
    '94 VR Exec
    Had a VX V6 doing something similar today. Went fine if you drove it gently, but wouldn't go over 40kmp/h if you tried to accelerate harder. Felt like it was running out of fuel and wouldn't go any faster. Tried the fuel filter, cleaned the throttle body, and put it on the scan tool but no luck. Delaying the inevitable really :p I swapped the fuel pump this arvo and now it's all good.
    Get a new pump, filter, and drain the fuel from the tank then try wipe and clean it out as best you can, otherwise you'll void the new pumps warranty.
  5. fatboyvk
    fatboyvk New Member
    taihape
    1995 vr commodore
    i swapped the iac because it was broken how could ihave done it wrong
  6. fatboyvk
    fatboyvk New Member
    taihape
    1995 vr commodore
    oh and it will go as fast as you want if your gentle just when you dump it it dies
  7. fatboyvk
    fatboyvk New Member
    taihape
    1995 vr commodore
    all fixed was just the outlet on the throttle body for the map sensor it was blocked
