[Buick] VR V6 in VNs1, teething troubles
savage1987
Donating Member
www.facebook.com
Got an issue in my VN.. just put a VR V6 in it, fresh rebuild.. it idles fine, lovely even, but stutters under load. Seems to be dropping 1cyl under the slightest load.
All the ignition gear was used on the previous engine, same coil and DFI, same leads and plugs even..
I have tried 2 sets of plugs, an NGK 13 and an NGK 15, but no change.
Motor is stock apart from bolt ons.
Any ideas welcome, want this thing driving asap.
Immortality
Staff member
Sth Auck, NZ
check all the connections, hoses etc. did you forget the MAP sensor hose by any chance?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
could be fuel pulse from not having that dampner.or it could be from running the vn tune.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
engine side of throttle butteryfly
savage1987
Donating Member
www.facebook.com
OK have checked the TB and all connections there are present and secure
I removed the DFI/coil packs and scraped back the mounting surface for better earthing, also tidied up the earth strap to the DFI.
No change.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
could be to much timing on a fresh rebuilt engine is it a stock vn tune or a custom special from the vn.you need to get it sorted it wont bed in the rings to well without running right
Immortality
Staff member
Sth Auck, NZ
are you sure the key was on the crankshaft snout before fitting the ballancer?
check fuel pressure, what do the plugs look like after it splutters?
checked fault codes?
Zuicider
Banned
Stonedville
Set of thongs
if the key wasnt on then the bottom timing sprocked would be spinning
savage1987
Donating Member
www.facebook.com
Not sure how to check codes on VN.. someone tell me and I will do it. 90% sure there won't be any codes though, no engine light.
greenfoam tune from the VN, a safe enough tune for 91RON on a VN engine.. surely the extra 0.5 compression point wouldn't ruin it.. jason said it should run ok. He's mailed me a VR manual tune on a VN memcal anyway, just waiting on arrival
Will pull plugs after new ones go in, hard to tell with 2nd handies
