VR V6 into VN series I?
potshots007
34
Mildura
VN series II custom :) and VZ exec
hey there everyone, just wondering, i bought a VR V6 motor and i was wondering if i can still use my radiator and everything or do i have to change everything over to series II? got me a little confuse so any help would be great
cheers, nick
AlpineRaven
41
You wouldn't have any problems, But in my opinion you should use VN SII wire loom & VP SII memcal in the ECM computer, then you won't have any problems running the engine in VN SI. With the Rad - its the same. Oh if you want you still can use the VN SI exhaust but I am against the idea, whereabouts that you should upgrade to SII manifold.
That what I did with my VN SI wagon that I sold about 4 months ago, VR engine in VN SI with SII wire loom & VP Computer. Runs really well.
AP
potshots007
34
Mildura
cool, thanks man, just wasnt too sure about the radiator as they are different, but i will see how i go i gues, and yeah i have the wiring lom and ecu already for it from a VP
cher, nick
AlpineRaven
41
Sweet. Another thing you might notice but (gee I just came home from work from night shift and can;t remember what its called) I think its angle or knock sensor that VR has that VN doesn't have. That is why i said to get SII wire loom, yeah VP on will do as there is no difference but not VR one because I know its different. Let us know how you go! Good Luck!
AP
potshots007
34
Mildura
yeah im getting there slowly, still rebuilding it, but just getting ideas of what else i may need to do to the cooling system as i thought they may not work
cheers, nick
kezvn
vnexecutive wagon
ive just done vr series 2 into vn series 1 couldnt find vn motor without a million kms on it used vr wireing harnes also vr radiator and purge tankuse exausr sensor from vr vn has 1 wire vr has 2 wire fit 2 new engine mounts and vr exaust manifolds total cost 950 that included motor with 143000 kms on it car goes like cut cat and better on fuel but in saying that old motor had 292000 so it was preety stuffed it spun bearing not worth repairing have fun
