delcowizzid
on holiday
If you have your original tune fit that and see what it does
Delco i will try the original memcal. What would happen if I leave the Mace memcal in. Will the ECU make adjustments within its parameters? Or will i need to send it back and have it retuned?If you have your original tune fit that and see what it does
This was done on my VS by aceventura thanks mateHad a look under the hood for a reminder and I have 2 additional earth wires running to earth points on the front of the block. One goes to the point on the bottom of the alternator bracket and the other to an earth point just below this. I don't believe I cut into the loom anywhere but just made sure the O2 sensor had 2 separate earths. I figure I didn't earth onto the firewall but I couldn't see too well in the gathering gloom and I would have to pull the inlet pipe off to get a good look.
