vr v6 running on 4 cylinders
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Pantha91, Oct 9, 2012.
  1. Pantha91
    Pantha91 New Member
    Vs s pack
    My vr commodore is missing pretty bad an then even worse under load I've changed all the coil packs, plugs and leads still no change, checked they all have spark and all the injectors were fine it seems cylinder 3 an 5 are not firing even though they have spark and fuel??? Anyone?
  2. Pie-VK
    Pie-VK That guy.
    Wollongong, NSW
    Series I VY SS Ute 5.7/M6
    check compression maybe?
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Check plug leads are OK and they are fully pressed onto plug nipple - hold finger against injectors on 3 and 5 while engine running (be careful!) and check you can feel them click.
    Maybe swap DFI module.
