VR V6 Slams Into Gear
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by SUSVS, Mar 21, 2011.
  1. SUSVS
    SUSVS New Member
    Plumpton
    VX S PAC
    Hi guys im new to the place so i will introduce my self quickly, My names Miikey im from Mt Druit and i drive a Silver VT Berlina and a Gold HSV VR V6, both are pretty much standard altho the VT Has 20's on it,
    anyway, in my VR im having a problem with the gearbox or motor, not 2 sure which 1 it would be but i can start the car and drive it for awhile then the gearbox/motor light comes on on the dash and then the gears slam into gear, i have changed the gearbox and changed the ECU but it still happens,
    any feed back would be greatly appreciated because its a beautiful car and i want it 2 perform at its best
    Thankx in advance
    Miikey
  2. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    check error codes will probably come up code 19 21 or 22 TPS sensor related
  3. Zarconia
    Zarconia Outrageous Fondler
    Rockhampton
    2010 R8 Maloo
  4. SUSVS
    SUSVS New Member
    Plumpton
    VX S PAC
    i did the codes and it came up with 12 and 13, which sensor would 13 be and where is it located??
  5. Zarconia
    Rockhampton
    2010 R8 Maloo
    Code 13 - Oxygen Sensor (O2) - No Signal
    The sensor is on the header just before the cat. Take the negative lead off your battery before fooling around with it.
    I dont see how this would be related to your specific problem though
  6. SUSVS
    SUSVS New Member
    Plumpton
    VX S PAC
    Bump back to the top anyone got a idea?? Iv changed rear end control arms n bushes n the ecu but it's got
    Me stumpt
