vr v8 auto issues
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by shaunc1988, Sep 21, 2013.
  1. shaunc1988
    shaunc1988 New Member
    wodonga
    vx lumina
    hey guys my auto is playing up it drives fine when in drive but if u manualy select a gear take your foot of the throttle it drops back to idle then when u put your foot down to acelerate it wont engage the gear until the revs have been raised to the corect point so it sort of free revs in gear until a certain point
    ANY IDEAS
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Checked your fluid level?
  3. shaunc1988
    wodonga
    vx lumina
    Yeah mate looks fine I change it regularly too filter aswell
  4. jgtoranalc
    jgtoranalc Member
    Adelaide, SA
    Holden Statesman VR HSV 5L, Holden Torana LC
  5. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    if the cel isn't coming on and i'm guessing this would have been suggested in the first post then........ it's not an electronic (solenoid, sensor or pcm) failure.... more likely a mechanical failure in the trans itself, stuck/worn check ball in the valve body or a blown piston seal is my educated guess (will select a gear and drive fine while there is sufficient line pressure but the second it's relying on low pressure and idle engine rpm there's sfa line pressure to keep the clutches engaged, it sits there waiting for something to happen... trans reco time).
    By the description then when you are heading down hill and manually select a gear to use some engine braking then there is nothing? even when you throw it back to 2nd down hill at 100 km/h, car keeps heading downhill gaining speed and engine sits on idle rpm (maybe 1000-1200 rpm)?
  6. jgtoranalc
    jgtoranalc Member
    Adelaide, SA
    True... I guess if it was the Solenoid then it would be having the problem all the time...
  7. DJ_Cosmic_Fire
    DJ_Cosmic_Fire smarter not harder
    South East Queensland
    VP S-Pack Oct '91 - VT SrsII Wagon - VE SV6 SrsII
    accumulator related issues, here - ie, inconsistent line pressure, could be trans pump related - means trans out at worse, check pressure points as per ATSG guidelines
  8. Jxfwsf
    Aus
    commodore
    I dare say an accumulator issue would result with inconsistent gear shifts (harsh/sloppy and random) in normal operation in D/OD, either way, still sticking with a major internal fault.
  9. DJ_Cosmic_Fire
    yeh mate clutch plates toasted most likely plus accumulator related & pump issues = trans out, rebuild time
  10. shaunc1988
    wodonga
    vx lumina
    its showing code 83 which is tcc pwm solenoid anybody replaced this before
  11. shaunc1988
    wodonga
    vx lumina
    the car was driving fine then five minutes later it did this it still drives and shifts perfectly fine when i put my foot down it still drops back and doesnt seem to have lost power or anything.after reading up about what the solenoid does it sounds like this is what it will be .i just hope it lasts long enough for me to save up for either a new auto or a manual conversion
  12. shaunc1988
    wodonga
    vx lumina
    i will fit a nem solenoid and replace the harness and see how it goes if someone has done this before any info would be appreciated
