NickVR
- Jun 11, 2006
- 1,414
- 24
- 38
- Age
- 40
- Location
- Adelaide, SA
- VR Executive A4 V8
I have (as many others have) used the AU Falcon fans, you can also use EF-EL Falcon fans too. The factory setting for theses is about 106degrees from memory. I have used the fan plug that was already on my car (on the body loom not engine loom) but you won't be able to do the same unless you can find which terminal that activates it where it connects to the body loom. But you can wire up and external fan switch which has a probe that feeds into the top radiator hose and that will turn them on depending what temp you have it set at. Davies Craig make them and they should be easy to find on ebay or even the local auto parts store. Here is how I did the thermo fans on mine> https://forums.justcommodores.com.au/threads/how-install-au-thermo-fans-into-vn-vs-v8.159896
