VR v8 injectors flow rate?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by justcommdave, Aug 27, 2006.
  1. justcommdave
    justcommdave Guest
    Hi there I was just wondering what the flow rate or standard VR v8 injectors were and is it worth going abit bigger to get some more HP, is it worth getting a bugger 70mm throttle body from standard 65mm thanks
  2. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    increasing the flow rate will require a recalibrated memcal as the flow rate is programmed into it.
    you will gain no extra power from the injectors
    the std ones will flow plenty for most street applications.
    a bigger tb may increase power.
    Cheers Rob
  3. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    You wont need bigger injectors until you run around 8 psi of boost (just to get an idea of why standard 20 lb injectors are fine)
