VR V8 Stato Stalling
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VR Stato, Feb 26, 2011.
  1. VR Stato
    VR Stato New Member
    HR Holden
    Hi Guys, You have all probably seen this before but......My 5.0 keeps stalling but starts a few minutes later, and is progressively getting worse. I have replaced the Ignition Module, and still no luck. It spits code 12 at me, I have spark when it stalls and cranks over without starting and still has spark, The fuel pump is new and I can hear it working when turning ignition on.
    Any Ideas??
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Id be checking the hall effect sensor in the distributor,it can cause problems like your having,and sometimes it wont even log an error code to notify you that its got a problem ....
  3. VR Stato
    VR Stato New Member
    HR Holden
    Would the hall effect sensor throw code 46 if it was cactus?? as Im still getting spark
  4. Brett_jjj
    Tamworth NSW
    vs commodore
    I havent got a list of the V8 error codes handy to look at, so Im not sure exactly what the error code 46 is on the V8's.But if error code 46 is something to do with the ignition system or ECU ,then yes,Id say it could cause that error code to set.The ECU might also use the pulse generated by the hall effect sensor to fire the injectors, so maybe thats why you still have spark but no go.
  5. VR38
    VR38 Well-Known Member
    VB SL/E
    How good is the spark, weak spark will fire but not enough to run.
  6. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    You need to see if you have fuel pressure then. The pump might be shagged. Put a gauge on it and see. To me it sounds like your coil is shagged though. If you replace it, move it to a more convenient position.
  7. VR Stato
    VR Stato New Member
    HR Holden
    Ok, Coil replaced, enough spark to start a bush fire, sprayed some aerostart in when it trys to stall and revs pick up, so will have a look at fuel pump tomorrow, Although its is only 3 months old.
    replaced do far:
    Ignition unit
    Coil
    Fuel pump
    New injectors
    Distributer cap
    Plugs
    Leads
  8. VR38
    VB SL/E
    Try testing the fuel pressure, both running and static, do you have a gauge to test the fuel pressure?
  9. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Id say Crank Angle Sensor.. but V8's dont have them eh?
  10. dirt drifter
    dirt drifter white trash hillbillie
    massive hole in the ground
    VS 5L M6 VS 6L M6
    check your battery leads/connections, specifically the earth.. my 5L vs did this a while ago. had spark, fuel pressure, no codes.
    wouldnt fire, then fired up but missed big time when it warmed up.. turned out to be a loose earth lead on the motor
  11. BottleFedVS
    BottleFedVS Member
    Around WA
    VS Calais 5.0L & 80 Series Landcruiser
    the hall effect trigger in the V8 distributer is their CAS!
    and yes it also fires the injectors.
  12. vscaprice98
    vscaprice98 New Member
    brisbane
    vs caprice
    thats right the hall efect sensor is also ur fuel injector timing
