Aussie_JD
- Apr 21, 2020
- 7
- 0
- 1
- Age
- 40
- Location
- Brisbane
- VR 5.0i 5spd
Hi, i have recently stroked my 5l in my VR and fitting yella terra flywheel and exedy clutch. once fitted to the car the clutch pedal was only half way between the floor and brake pedal at full adjustment. I have had to remove the engine again due to compression issues and have just removed the clutch fork to see if that the issue with the low pedal. Can anyone confirm if the clutch fork should be completely flat, or have a dog leg in it (photo attached.). I am adjusting the pivot ball another 2mm as its at 103mm not 105mm. Not sure if the flywheel and clutch combination would have anything to do with it. Yella Terra flywheel uses a vn clutch not vr, but as far as i know the bolt holes are the only difference. Thanks in Advance.
