As the Manager of an Automotive Airconditioning Company and 12 years of doing A/C work I would like to point out that I get around 4 to 5 VR-VS' in a month with the problem stated. I'm not blowing my own horn so PLEASE take the following as advice and not critisism.
The o'rings only seal the fittings, the nuts that go onto the reciever drier are the problem! The nuts are alloy and the drier is metal, these can, in a lot of cases but not always, cause the nuts on the fittings to corrode (grow onto) the reciever drier. This is a chemical reaction between the two metals.
Garth you where right in stating that the reciever drier can not be maintained, and yes it should always be replaced if the system has been opened up, but It is, in the A/C industry, common knowledge that the reciever drier be replaced every two years, obviously by a qualified tech due to the high pressures. And no they are not normaly servicable items (WB/HZ being the exception but only by a qualified technician) and SHOULD NOT be touched by the general public due to the very high pressures involved. The reason for replacing the drier is due to the fact that it has three main functions
1. To remove any moisture from the system due to the very slight permitation in some systems and/or poor servicing. It has a limited capacity and once "full" is unable to perform this function which can lead to corrosive problems in the system and/or the possiblity of sending the dessicant into the Tx valve causing a blockage.
2. To remove particals from the system due to any corrosive activities in the system, due mainly to moisture in the system, and the mechanical breakdown over time of the compressor (it does have quite a large number of mechanical moving parts, i.e wearing parts). If this gets to a point where it blocks up it may cause a blockage in the system, thus no cold.
3. To act as a vapour seperator so the TX Valve gets a constant stream of liquid to it for optimum performance.
I'm not sure by your comment on using the A/C duing winter to get the heater working but you where correct that not many people know to use the A/C duing winter. I believe in the theory that it stops leaks happening by lubricating the o'rings (which are mostly made up of a rubber known as HNBR NOT teflon except in the hose connections on York (Early Ford) compressors and some shaft seals)and the compressors shaft seal.
I am sorry if I did not explain myself correctly in the first post, hope this clears it up a little for everybody. KIND REGARDS.
