vr vs brake discs
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Yes they are.
Unless one is a HSV with upgraded brakes.
VR38
VB SL/E
Solid and IRS rear are different.
luckyvt94
30
Hobart Tasmania
vz Thunder SS
Mine is solid. So if I pull the disks out of the vs that I'm wreaking that dose have solid axel they should fit
VR38
VB SL/E
Solid axle brakes are same same.
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Take note to install the thickest rotors too. Runout check would also do good. Even service the calipers and handbrake assemblies
Saves you coming back later to face future problems.
