NKX
- Dec 24, 2003
- 58
- 6
- 8
I was asked to put this in the how-to section by some poeple on the site... apparently its useful. You can see the post from which it originated at:
Post #40029.
Here are the instructions; These can be used to help you:
a) not break the plastic when removing the dash,
b) replace the instrument cluster with an after market one, or
c) replace/check for blown globes in the instrument cluster.
Hope you all find this useful.... more howtos on the way - as I have pretty much removed every bit of my car at some point or another lately.
Post #40029.
- Remove screws Orange 1 & Orange 2; these two screws are visable at the top of the instrument panel before removing anything. Dropping the steering wheel to its lowest position before starting helps.
- At this point you can remove the headligh selector if you wish, or else start removing the tabs holding the dash insert in. These are numbered Red 1 through Red 5. I personally like to remove the headlight/illumination switch and use that short side to start pulling the dash insert out.
NOTE: It has been mentioned that some people with ABS equipped cars, or those intending to leave the dash out for some time, have had issues with warning codes and flat batteries. If you think this will affect you - please disconnect the battery before getting started here.
- Using a flat-head screwdriver insert it to where the Red X numbers are and lift gently. The tabs should just pop out. I may have missed a tab location on the far right side near the headlight selector - I can't remember... see if it gives.
- After getting the insert loose, disconnect the Hazard light / Air Con / Demister plugs from the rear of the insert (and the headlight selector too if you haven't already done this). I find it useful to label everything here as I go - so grab a marker pen if you too intend to do this.
- Remove the now visable Orange 3 and Orange 4 screws. At this point the whole dash insert will just pull out. As you can see from the photo it is held in and made working by the Orange, Blue, Orange multi-pin connecters.
