this is all way over my head. I am running a VR auto (V6) in my VP on the original VP loom and ECU. It runs really nicely but I am (still) striving for better economy having changed MAT sensor, temp sensor unit and a bunch of other small stuff. I have the VR loom and ECU from the replacement motor. Is it worth fitting that to the motor?
Sorry I can't help with your questions and for piggy-backing on your thread[/
hrm, i was sure ecotec's were introduced in the VS not in the VR... time to do some reading......
If you're planning on putting a manual behind it then a reprogramming a VS ecu with the buick's timing and fuel parameters and using a VS loom on the buick engine would be quite doable.
Re pinning the looms for vr to vn/vp is easy i have a thread in the howto section based on putting a VR v6(buick), 4l60e, loom & ecu/pcm into a vn s2 and was pretty simple to get going.
more trouble than it's worth imo, would have to rewire some of the auto wiring to connect to the th700 and i'm still not sure it'd work correctly, vn/vp auto uses a different vss also which may cause problems with the vr pcm, speedo wiring would also have to be changed so it runs to the pcm instead of the trans like it will be now.
