VR VS - Move Head Unit to Center air Vents.
sweefu
VY Berlina V6 / R31 Skyline
It's different, and looks like you did a very good job mate. But I still think its pointless, your aircon vents are pointing at your gearstick.
Customcreations
PORTED GETS IT SORTED
Cessnock Australia
VS Commodore V6 EcoTech Custom Ported by me
Looks neat. Anyone would think it was factory. (anyone who got in a didn't know anything about the genuine setup that is)
What did you use for rerouting the A/C down further?
fuzzy2308
Plastic datsun
i like it, looks cleaner and would be more user friendly.
on_d_tox
VS spac S2
omg not my cuppa tea mate dont see any point in it just doesnt look right at all
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Looks like a car audio installer has pulled apart your dash then gone **** where did these go again. Looks wrong and is pretty pointless but each to their own I own I suppose.
sweefu
I just want to say again, it looks like a very professional job, it wouldn't have been a very easy task for most. Well done again mate.
frankfava
1994 VR Commodore S
Thanks to all, It really works for me,makes sense and much more user friendly. Unless you really want it, its a bit of work.
Head Unit Wires were easy enough to reroute, as they run underneath the dash anyways. The A/C being lower wasn't an issue as the vents swivel upwards, used a plastic container and some hose to "tap in" to the ducts (from both sides) that run to the rear seats and blocked off the port that went to the original vents. This actually worked for the better as it changed the airflow directing more air to the door and rear vents (where the "new" vents). Better airflow all round now!
The Vents once detached were cut and pretty much fit perfectly into the headunit surround, with about a 10mm gap on either side, a bit of araldite to hold it all in and bog to fill in the aesthetics went down a treat. The instrument panel surround was less cooperative, had to enlarge the hole width-ways (into the speed alert cavity) and fill it in height-ways. Pretty much a perfect fit behind for a standard unit, rests right on the port (now blocked) for the old vents and just clips in. Bit of Satin Black Paint to finish it all off and it came up nice.
Real happy with it!
DJ_Cosmic_Fire
smarter not harder
South East Queensland
www.house-mixes.com
VP S-Pack Oct '91 - VT SrsII Wagon
OP - wow that would have taken alot of work! Looks good (on 4th look) & I imagine it works very well for you, just not a Commodore anymore IMO. Pros would be :- you can reach & adjust the vents much easier & Cons would be :- indistinctly going to adjust stereo without looking & reaching for the ducts, guess you'd get used to it after awhile (I use the remote these days, much more function control & less wear n tear on the little HU buttons etc).
