VR - VS UTE Power Windows Wiring Diagram
Brett
Legend
Gladstone, QLD
VZ SV6
Im after the power window wiring diagram for the VR - VS Ute and also the cruise control one, but must be for a ute.
Any help will be appreciated.
Thanks.
paulsautoelec
52
darwin
vr ute
wiring diagram is same for ute ,sedan,wagon just minus the two rear doors
NickVR
Adelaide, SA
VR Executive A4 V8
Brett
Legend
Gladstone, QLD
VZ SV6
Cheers for the post mate.
I have used the search button before and alot of the info is all over the shop.
I just want the diagrams.
NickVR
Adelaide, SA
VR Executive A4 V8
Unfortunately you just gotta sift through it all. But it's all there if you want it.
Brett
Legend
Gladstone, QLD
VZ SV6
Theres no ute stuff and the wiring would have to be different for the window switches. Anyway thanks for your help hopefully someone will pop up with the diagrams.
That or i may just go and buy a repair manual and post them up myself :)
hitman1979
Alice Springs NT
VE SV6
try this mate, this would work for the switches as they are the same as the rear door power window switches in the sedans.
the only thing that would be different for the VR-VS is the wiring that goes to the power window module for the VN-VP would go to the body control module in the VR-VS
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Think I read somewhere in one of those links that NickVR posted (I recently fitted CC) that the low series BCM in the ute will support CC but not PW.
