Vr wagon stuck i first gear
cartwright
30
alice springs
vr wagon
Hey ive got a vr wagon that only drives in first gear, i read through lots of threads and people were saying it could be the tps (throttle position sensor) which i was hoping it was but i checked the error codes and its 12 which means everything is fine, so im pretty confused bout what it is??
Any help will be appreciated! Thanks
deanos70
have you checked your transmission fluid level
when was the last time you had the filter in the gear box changed
cartwright
30
alice springs
vr wagon
Hey yeah i have checked it, it was abit low but i filled her up and didnt do much difference! i dont know if it has been changed, only had the car for 3 months
D3V14NT
Likes Shiny Things
Geelong, Vic
93 VP BT1 V6
assuming it's an auto? Does it go into reverse and will it shift into 2nd if the shift lever is placed in second or is it always first no matter what the selection? Have you tried going as fast as you can in first to see if it'll skip second and shift into third? Might be a problem with the 2-4 band slipping and not engaging 2nd.
A service wouldn't go astray but if you can't shift gears at all I can't see it resolving that. You didn't overfill it with fluid at all? If you can borrow a tps from a mates car give that a go and see what happens. Apart from that check the electrical plug to the trans to make sure it's connected correctly and hasn't come loose. Is your speedo working correctly as a dodgy Vehicle Speed Sensor can cause problems with shifting too.
If none of that does the job I'd recommend taking it to a transmission specialist who'll have a much easier time of diagnosing the problem.
If none of
Paintabruh
campbelltown
VR commodore acclaim V6
ule need a new transmission prob urs is worse then what mine was i could get to second then accelerate her to get to 3rd but after nerrrrrrrrrrrrrrr...
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
sounds like its time for a
new transmission ? hope im wrong
deanos70
mate if your taking the old box out
now would be a good time to replace the rear main seal if its leaking, they are only about $30
and also get a new rear seal for the transmission where the tails shaft goes in they are only a few $$$$
