VR Wagon
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by willysvrwagon, Apr 14, 2008.
  1. willysvrwagon
    willysvrwagon New Member
    vr s2
    Hi there
    I am new to owning a holden as I have had fords all my life. My car is not running right and I am wondering if anyone could help me.
    My car has not got the ecotech motor.
    The car seems to idle fine at 1000rpm but if I accelerate hard it seems to want to die. (like a hard flat spot)
    I have found th error codes for it and they are
    31- Theft deterant signal
    55 - Analogue to digital error
    56 - Running lean under load
    I have changed the MAF sensor, injectors, Leads and Plugs.
    I have also tryed a VS Coil Pack.
    I am just wanting to know if is anyone can shed some light as to how to fix my problems.
  2. Pimpn1
    Pimpn1 New Member
    Adelaide, SA
    None
    maybe there could be a vaccuum leak or fuel pump problem, not too sure though correct me if im wrong
  3. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Code 56 indicates that there could be a problem with fuel pressure.
    The codes you have may be old ones. Try clearing the codes by disconnecting the negative battery terminal for about a minute and then reconnect it. Then run the car for while (go for a short drive) and then read the codes again and see what you get.
    If you have the stock radio you will need to enter the PIN after disconnecting the battery.
  4. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    I read somewhere, most likley on JC, just remove the main engine fuse for a minute and then replace. Then you won't need to re-enter the radio PIN code.
