[VR] wiper washers not working
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
I've unblocked the washers on the bonnet and all the tubing, the motor is working from what I can tell (I can hear it).
I tried disconnecting the pipe before it splits off and goes to the washers, water won't come out there either so the problem is somewhere along that tube that leads back to the water container or somewhere in the water container underneath the air filter.
what should I check? I'm sick of my windscreen being filthy! lol
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
I say replace the pump, even though you can hear it, it can still be faulty.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Take the washer bottle all the way out. take the tube off (that goes to the bonnet)
Connect power and see if the motor squirts water. If so - unblock tubes.
See if you can blow through the tubes. If so, check the wiper switch/wires.
VS_Pete
Donating Member
Try this.
go down to petrol station.
connect up type gauge to tube going to bonnet blow out.
seraphic06
Woodgrain Nut
Adelaide, SA
VZ Berlina Wagon, VS Caprice Series II 5.0
Remove the pump from the reservoir and clean the black rubber filter that fits over the inlet.
seraphic06
Woodgrain Nut
Adelaide, SA
ok how to do I remove the pump/reservoir? jack the car up?
It is located in front of the front left hand wheel. No need to jack your car up. Get your socket set out, remove a couple of bolts, disconnect the water lines and prepare to get wet.
seraphic06
Woodgrain Nut
Adelaide, SA
ok see how I go on saturday. wreckers fine for a pump if needed?
Shouldn't pose a problem - just get one suited to your car. The pump in a sedan is different from that of those in a wagon (it has an extra water line for the tailgate).
