VR wiring Diag
iank
VR
Gents,
I am trying to locate wiring schematic for my VR auto.
Specifically how the cooling fan relay is switched and wired.
thanks
Ian
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
heres the diagram
iank
VR
Thanks
Many thanks for the prompt reply & diag.
I am going to modify it so that if the fan is running at the time of engin switch off the fan will continue to run for a few minutes.
Despite all the cooling system checks out OK & holds pressure OK when hot, mine runs vey close to overheating when switched off on a hot day.
PS the left hand side of the image sent is clipped, I have all the info I need but if theres anything worthwhile on the LHS and its not a hastle I would appreciate it.
I am heading off on hols so wont be logged on again for a couple of weeks.
Again thanks for the help/
iank
VR
The Final answer
Well the problem turned out to be the system was pressurising OK but on really hot days when the engine was turned off the cooling system did not stay presurised long enough resulting in the coolant occasionally boiling.
The radiator neck appears ok but I think it has warped slightly (like me).
Interestingly the lower plastic radiator tank outlet is very oval in shape co it looks like the plastic tanks can distort.
Any how no further problems since I replaced the radiator.
Thought you might be interested.
:dance:http://forums.justcommodores.com.au/images/smilies/dance.gif
:dance:
