VR won't go (code 46)
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jlm90, May 17, 2012.
  1. jlm90
    jlm90 New Member
    Bundaberg
    VX S Series 2 and VR Wagon
    I've got a VR and it wont go.
    Out of the blue one day it just started stalling quite constantly, luckily I was only about 1.5km's from home and managed to get it home (stalled 4 times). Since then it wont start at all, it will turn. Displayed codes 46 and 48.
    I've replaced the CAS and has made no difference. Now displaying code 46.
    Anyone have any ideas??
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Did you reset the ecu?
  3. VR38
    VR38 Well-Known Member
    VB SL/E
    V6 or V8, either way it is not getting the signal to fire the coil/s.
  4. jlm90
    jlm90 New Member
    Bundaberg
    Yep, battery was disconnected while removing harmonic balancer.
  5. jlm90
    jlm90 New Member
    Bundaberg
    V6, thats what I figured, i also tried changing coils and it is pumping fuel as I took the fuel line off the injector rail.
  6. wraith
    Demonicaland
    Could also be the balancer its self. Sometimes the fins can be bent a little. It's stupid but I replace the balancer when I do the CAS.
  7. VR38
    VB SL/E
    Wires not loose or damaged?
  8. jlm90
    jlm90 New Member
    Bundaberg
    I'm hoping its not the balancer, its only a about 8-12mths old.
    I've looked over the wires and can't find any faults with them.
  9. VR38
    VB SL/E
    At both ends, sometimes it can be at the module end.
  10. jlm90
    jlm90 New Member
    Bundaberg
    I'll have to check tomorrow. Be nice if it was that simple.
  11. VR38
    VB SL/E
    Undo the bolt and make sure it is clean too while your looking.
  12. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    could also be a dodgie dfi module. try swapping it for one of your mates if they have a vr/s. this will help eliminate it
  13. jlm90
    jlm90 New Member
    Bundaberg
    I may even just pull the dfi module off and swap it. I've got a complete spare engine/car.
  14. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    i'd definitely try another dfi module, 46 can be caused by that or the cas, you've replaced one bit now try the other....
