VR wont run HELP!!!!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jrosullivan, May 23, 2012.
  1. jrosullivan
    jrosullivan New Member
    pottsville
    VR 5spd
    its firing and not starting we put a bit of petrol done the intake and it started for 1 sec
    we just replaced the ignition barrel and key could this affect anything why it wont start
    can any one help
  2. Chrispy
    Chrispy Member
    VZ Calais, 2015 Daytona 675R
    When you turn the key to on can you hear the fuel pump prime? Get a friend to listen. If it's starting when you put fuel into the intake, the car obviously isn't getting fuel.
  3. jrosullivan
    pottsville
    VR 5spd
    you can hear the fuel pump buzzing i just put a new one in it and its still not firing would a emobiliser or anything to do with the ignition be stoping it from getting fuel ????
  4. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    The immobiliser can stop the fuel injectors from working when its active..Try leaving the ignition switch in the on position for 45 minutes (which bypasses the immobiliser)and then see if it starts. If it does start, its the immobiliser causing the problem. Make sure the battery is fully charged and all accessories and interior lights etc are turned off before leaving the ignition switch on for the 45 minutes. Also if it starts after the 45 minutes, once you turn it off again, you will have to leave it for another 45 minutes before it will start again. This bypass time period is basically a safety feature, so if the car has a problem with the immobiliser, it can be started and driven (after the time period it up) to a workshop for repairs etc.
  5. jrosullivan
    pottsville
    VR 5spd
    cheers mate that should solve that problem now i just have to work out why the new fuel pump itsnt buzzing anymore
  6. Brett_jjj
    Tamworth NSW
    vs commodore
    When the ignition switch is first turned to the on position, the fuel pump should only run for about 2 seconds or so, then it will cut off again. It wont run constantly until the engine is actually started..
