Vr304
Donk lyne
47
Tassie
Vr ss 304
Hi there peep I've got a vr ss 304 after market radiator with twin thurmo fans and it still gets hot would it hurt if I took the thermostat out cheers
losh1971
North Tas
VE Series I SS Ute
Is this an eBay rad set up? If yes, there lies your problems. The clutch fan pulls a stack more air than cheap twin thermos. Plus those eBay alloy rads if that's what you have are not great. I installed one in my V6 and even though it held more water it didn't perform like I thought it would.
If you're dead set on thermos then you will need some that can pull a lot more air than those you have and you will probably need to upgrade the alternator to cope.
losh1971
North Tas
VE Series I SS Ute
Where are you located? If you are near me I can put you onto a cooling system/AC expert who can get you something that will work well. It won't be cheap though.
gtrboyy
vt ss & lc gtr
Silly idea to remove thermostat as a bandaid measure...just need to drill 2 small holes so can bleed air out.
Point of it is to slow water down enough for heat transfer.
Didn't say or show pics of actual radiator & thermofans....most aftermarket fans are crap.
Ford mondeo or au fans etc work great but need bigger 120a alternator + better wiring.
A setup I like is vs series 3 2 core replacement with vs v6 thermofan...bolts on & looks like factory also able to keep stock 85a alternator.
Deuce
Super Stock
'94 VR SS V8
I got a 'police spec' rad, I think it was adrad. Cooler temp 'high flow' thermostat. Stock fan and shroud.
Stays pretty even temp even when thrashing or towing or whatever.
Buy a good radiator. It'll be the best money you ever spend on it.
My rad was over $600 but well worth it.
Donk lyne
47
Tassie
Vr ss 304
Yer might put a clutch fan on thanks
