Draimond
- Aug 28, 2008
- 354
- 336
- 63
- Location
- Brisbane
- VS V6 Executive
This is my build log for my 4th and current daily drive VS Commodore.
Purchased in 2021 with only 90,000 kms on the clock and full mechanical history.
Sharing my detailed info incase it helps others with their builds.
The goal is to have a V6 Turbo for street and track use.
I'm not great at record keeping so assume there's at least $1,000 that I've forgotten to add here.
Will update this table as I go.
Spent | $21,750 | Est. Total | $25,099 | Still Needed | $3,349 |
Part | Spent | Estimate | Supplier | Type | Details |
VS Commodore | $3,000 | $3,000 | Private | 1996 V6 Sedan White | Non ABS & Airbag Auto |
ECU | |||||
Haltech ECU | $2,164 | $2,164 | Haltech | Elite 2000 | Plug & Pin Set Inc |
Dyno Tune | $800 | The Hoff | Cleveland Exhaust | aka Nugget Garage | |
Wiring Harness | |||||
Connectors -Cam, Crank | $17 | $17 | EFI Solutions | 3 Pin GM Cam, 4 pin LS 2 Coil for Crank | |
Connectors - Coils, TPS, IAC | $60 | $60 | eBay | 6x LS1 Coils, TPS, IAC | |
Connectors - 12V Supply | $28 | $28 | EFI Solutions | Deutsch DT, 1x 6 pin, 1x 8 pin | |
Wiring - Cam, Crank, Knock | $56 | $56 | NRT Automotive | Raychem | 20awg Raychem Spec 44, single core shielded wire |
Wiring - Ignition Coils 12V -12V | $50 | $50 | NRT Automotive | 12awg Coil Ground & 12V Common Tefzel | |
Wiring - Ignition & Fuel | $100 | $100 | NRT Automotive | 20awg TXL, 20awg Tefzel, Injector & Ignition wires | |
Sensors | |||||
Wideband O2 Sensor Kit | $448 | $448 | JDMyard | Haltech | WB1 Bosch Single Channel CAN O2 Kit |
Flex Fuel Sensor | $159 | $159 | EFI Solutions | VDO | 3/8 lines, 3 pin connector |
Knock Sensors (x2) | $90 | $90 | Golby's | Bosch Motorsport | Bosch 2 Wire |
Fuel Pressure Sensor | $249 | $249 | Haltech | Haltech | 250 psi |
Intake Air Temp Sensor | $44 | $44 | EFI Solutions | Bosch | M12x1.5 thread. 2 wire |
Oil Pressure & Temp Sensor | $109 | $109 | Golby's | Bosch Motorsport | Temp Pressure combo |
Coolant Pressure & Temp Sensor | $109 | $109 | Golby's | Bosch Motorsport | Temp Pressure combo |
Engine | |||||
Head Studs | $180 | $180 | Mace Engineering | ARP | ARP601 |
Turbo | |||||
Turbo - Temp | $300 | $300 | eBay | T3 GT3582 | |
Turbo - Good Quality | Mamba Or Kinugawa | T3 Ball Bearing | |||
Boost Control Solenoid | $149 | Golby's | Haltech | 3 Port | |
Turbo Oil Pressure Reg | $185 | $185 | eBay | Turbosmart | OPR V2 |
Oil Feed, Return Adapter | RCE Performance Warehouse | Aeroflow | |||
Oil to Turbo Parts | $154 | $154 | EFI Solutions | AN4 PTFE Hose & Fittings, Weld on AN10 & AN6 | |
Turbo - Hot Side | |||||
Waste Gate | $452 | $452 | eBay DDI Auto | GFB | EX44 kit inc v-band etc |
Exhaust Manifold Flanges | $85 | $85 | eBay | 43mm Ports, 12mm Plate | |
Turbo Manifold Steam Pipe | Supersteel Australia | Cast Mild Steel, 40nb & 50nb | |||
T3 Flange | $35 | $35 | eBay | 12mm Mild Steel 4 Bolt | |
T3 Studs | $16 | $16 | eBay | Stainless Steel M10 x1.25 studs x5 | |
Dump Flange | $23 | $23 | eBay | 12mm GT35 3" 4 Bolt | |
Crossover Pipe V-Band 2" | $24 | $25 | eBay | Stainless V-Band | |
Exhaust Flex Joint 1 3/4 " | $30 | $30 | eBay | Aeroflow | Aeroflow Stainless 1 3/4 Inch ID |
Exhaust Flex Joint 2 1/4" | $32 | $32 | eBay | Aeroflow | Aeroflow Stainless 2 1/4 Inch ID |
Dump Pipe | $200 | $200 | Stainless 3", 2x 90°, 1x 45°, Straight Pipe | ||
Ceramic Coating | $600 | ||||
Turbo - Cold Side | |||||
Blow Off Valve | GFB | GFB | |||
Intercooler | $112 | $112 | maxspeedingrods | Chinese | 533x178x57 core, 2.5" in/outlet. Delta fin |
Compressor Outlet V-Band | $65 | $65 | RCE Performance Warehouse | Aeroflow | AF92-2250D Aluminium 2 1/4 inch |
Intake Pipe 3" 90° | $49 | $49 | Goleby's | Goleby's | Aluminium 90° Mandrel Bend |
Intake Pipe 3" 90° Short | $35 | $35 | eBay | Aluminium cast short radius 90° | |
Intake Pipe 3" 45° Long | $30 | $30 | eBay | Aluminium 3" 600mm long | |
Intake Pipe 2.5" 90° | $33 | $33 | eBay | Cast Aluminium short radius 90° elbow 2.5" | |
Intake Pipe 2.5" Straight | $52 | $52 | eBay | Worley | Aluminium 1x 180° & 1x straight 600mm long 2.5" |
Silicon Joiners | $84 | $84 | eBay | Raceworks | Silicon 4 ply, 1x 90°, 1x straight 2.5" |
90° Silicone Reducer | $32 | $32 | Goleby's | Goleby's | 3" to 2.5" 90° Silicone Reducer |
Silicon Joiners 45° x2 | $75 | $75 | Goleby's | Goleby's | 2.5" 45° Silicon Joiners |
Pipe Clamps | $22 | $22 | eBay | 10 pack, T bolt pipe coupler clamps 2.5" | |
Intake | |||||
Reverse Intake Plenum | $380 | $380 | eBay - J Spec Fabrication | Modified stock plenum | Throttle to drivers side |
Manifold Insulator | $75 | $75 | Mace Engineering | Mace Engineering | M1642 12mm |
Vacuum Hose | $20 | $20 | Supercheap Auto | SAAS | Silicon 4mm |
Vacuum T Joiner | $10 | $10 | Supercheap Auto | Champion | Champion Brass 3/16 T Piece |
Brake Booster One Way Valve | $15 | $15 | eBay | 10mm Barb | |
IAT Sensor weld on fitting | $8 | $8 | EFI Solutions | EFI Solutions | M12 x 1.5 |
Ignition | |||||
Coils | $0 | $0 | Coffs Harbour Wrecking | stock LS1 coils, came free with other items | |
Ignition Lead Cable | $86 | $86 | ICE Ignition | 9mm pro 100 series, 100ohms per meter | |
Ignition Coil Connectors | $13 | $13 | ICE Ignition | 6x Coil Connectors | |
Spark Plug Connectors | $30 | $30 | ICE Ignition | 3x 45°, 3x 90° | |
High Temp Plug Covers | $27 | $27 | eBay | 1100°C Contact safe plug boot protectors | |
High Temp Lead Sleeves | $77 | $77 | Outlaw Speed | Proflow | 1100°C Contact safe 10mm Sleeve |
Fuel | |||||
Fuel Pump | $115 | $115 | EFI Solutions | Walbro | 255lph, 500HP |
Submersible Hose | $8 | $8 | EFI Solutions | E85 3/8 100mm | |
Fuel Injectors | $502 | $502 | Goleby's | Bosch | 1000cc E85 |
Fuel Pressure Regulator | $195 | $195 | Tuff car parts | Aeroflow | AF66-2058BLK |
Fuel Pressure Gauge | $36 | $36 | eBay - GFB | SUITS 8050/8060 5730 | |
Fittings - GM hard line ends | $68 | $68 | EFI Solutions | Screw on GM: 2x 3/8, 2x 5/16 | |
Fittings - Return | $32 | $32 | EFI Solutions | AN6: 1x ORB Straight, 1x 90° 3/8 barb | |
Hose - E85 rubber | $30 | $30 | EFI Solutions | AN6 3/8 E85 2m | |
Fuel Sender Seal Kit | $20 | $20 | Rare spares | eBay | |
Catch Can System | |||||
Catch Can | $0 | $0 | SSA | Free sheet metal offcuts | |
Catch Can Fittings | $83 | $83 | EFI Solutions | 1x 45°, 1x 60°, 2x 90° AN10 Pushlock Barb | |
Breather Hose | $58 | $58 | Dullys | Raceworks | Raceworks AN-10 Pushlock |
Rocker Covers Alloy | $385 | $385 | Mace | Polished Alloy | |
Weld on Breathers | $30 | $30 | Ian Boettcher Race Parts | Aeroflow | |
Weld Breathers onto Covers | $66 | $66 | Dullys Customs | Labour / Welding | |
Breather Air Filter | $15 | $15 | eBay | 1" inlet, small pod style breather air filter | |
Radiator | $150 | $150 | eBay - autoparts100 | WorleyMel | 3 Row Alloy |
Oil | |||||
misc fittings and hose | $260 | $260 | Ian Boettcher Race Parts | Aeroflow | 4x -10 orb strait, 2x 90 hose end, 2x strait hose end |
Oil Filter Relocation | $250 | $250 | Ian Boettcher Race Parts | Aeroflow | AF64-4112 with oil thermostat 82°c |
Oil Filter | $36 | $36 | Ian Boettcher Race Parts | Ford/Mopar | |
Oil Cooler | $200 | $200 | Maxspeedingrods | eBay | 13 Row AN10 Oil Cooler Kit w/ hoses & fittings |
Oil Distribution Block | $250 | $250 | Boosted Built Garage | BBG | |
Transmission | |||||
T56 Gearbox | $1,500 | $1,500 | Coffs Harbour Wrecking | LS1 VZ | 6 Speed Manual |
T56 Clutch Master & Res | - | - | Coffs Harbour Wrecking | LS1 VZ | Incuded Pedal Assy |
T56 Gearbox Adapter | $421 | $421 | Malwood Automotive | Malwood | V6 to LS1 Adapter kit & Spigot bush |
Flywheel & Clutch | $1,500 | T56 to Ecotec | Cushion Button, Light Flywheel | ||
Gearbox mount | $447 | $447 | Muscle Garage | Mounts and Crossmember | |
Tail Shaft | $400 | ||||
Starter Motor | $138 | $138 | onlineautoparts | eBay | VN Manual |
Diff | |||||
Diff Upgrade | $2,420 | $2,420 | Hart Transmissions | 4.11 Crown Wheel & Torqueworm LS Center | |
Diff Cover | $295 | $295 | DSM Motorsport | Alloy Girdled | |
Brakes | |||||
Front Brakes | $1,595 | $1,595 | Mac's Mufflers | Willwood | 4 Piston Calipers, 320mm Rotors |
Braided Brake Lines | Mac's Mufflers | ||||
Rear Brakes | |||||
Steering & Suspension | |||||
Sway Kit | $747 | $747 | Whiteline | Adjustable Kit | Sway Bar front and rear & Strut Tower Brace |
Rear Top trailing arms | $120 | $120 | Hart Transmissions | Pedders | Sports upraged design |
Coilovers Suspension | $2,000 | Showtime Customs & Fab | BC Racing | VT mod to Suit VS | |
Power Steering Rack | $297 | $297 | Aus Power Steering | Reco OEM | |
Lock Kit | $926 | Showtime Customs & Fab | Stage 2 | ||
Front Sway Link | Showtime Customs & Fab | Suits custom steering to Whiteline sway bar | |||
Battery Relocation | |||||
Battery Cable & Stud | $135 | $135 | Carlos Auto Electrics | 4 Gauge cable & 300 amp power stud | |
Exhaust | |||||
Exhaust Muffler & Cat | $299 | $299 | Cut Price Mufflers | Redback | High Flow Muffler & High Flow Cat & 2.5" Pipe |
Exhaust Resonator | $40 | $40 | Cut Price Mufflers | Redback | |
Gauges | |||||
Oil Temperature Gauge | $70 | $70 | eBay | SAAS | |
Oil Pressure Gauge | $70 | $70 | eBay | SAAS | |
Boost Pressure Gauge | $70 | $70 | eBay | SAAS | |
Pressure Gauge | $40 | $40 | eBay | GFB | 0-140 PSi Fuel pressure gauge 40mm 1.5" |
Interior | |||||
Steering Wheel | $459 | $459 | MOMO Montecarlo Black 350MM HDT | ||
Horn Button | $90 | $90 | HSV Logo VK-VP |
