VS 5.0L statesman not changing gear properly
darky82
VX Berlina S1 5.7L
Hi new to justcommodores, After any advice, Just changed my inlet manifold due to a water leak, aslo changed my thermostat from a 195deg F to a 180deg F because it was slightly getting hot with the weather we been having while using the A/C, all went well till i went for a drive, now when i cruise the auto box hesitates when changing, but if i flatten it it changes ok, but not kicking back, the temp stays a needle width above a 1/4 just wondering if its to cold and the computer still in cold enrichment mode try to warm the engine, had a stage 4 memcal in, i removed and reset the ECU and still the same.. help im DOOMED!!!
BlackVXGTS
Melbourne, SE
Make sure you haven't damaged the wiring connection to the TPS (Throttle Position Sensor) which is mounted on the throttle body.
