Vs 5L manual conversion
Wombles
Cars cost too much.
So for the 5L conversion, what do I need?
ECU?
T5?
Driveshaft?
Wiring for T5?
By the sounds of it I can still use auto loom, just swap a few pins for the ECU?
Flywheel?
Clutch?
Missing anything?
Anyone got clear instructions for the pin moves?
Disturbed_vegeta
I'd Prefer To ROAR!
35
Burpengary
Www.myspace.com
VR Hsv Senator, VX SS, VZ SS Ute 6L, K9 GSXR1000
you can still use the auto loom/ecu but youll have to get the memcal tuned for the manual(do a search for greenfoam) but heres the wiring i used but i forgot how i wired the speedo but heres a photo of what wires you have to work on (they go to the auto t-bar sensor thing so i'd just cut them from that.) all you have to do is, conect the black wire with the gray one(thats you neutral so it will start) then you have to run the green one and the pink one down to the side of the box where the is the reverse sensor, conect it to that ( i used some spade things so it sits in sweet) it doesnt matter which way you put them on the box because they'll work either way. hope that helps. also you need a spigot bush (can get it from repco for a few bucks) and the floor plate and pedal box/clutch cable..its a pretty basic conversion
<RaBBiT>
Follow the White RaBBiT>>
NSW Batemas bay
Grab new gearbox mount s and flywheel bolts . And need a clutch cable
304runner
( .Y. )
41
Central Coast NSW
VR 5.0 Ute & a 4runner with a VS SS trasplant
Pedal box, obviously...
A manual memcal in an Auto ECU will work also. Or as mentioned a reflashed auto memcal.
You will have to make sure the inhibitor switch is in Park or neutral after you remove the auto....Pretty self explanatory when you get to it, its just a dial essentially...
Wombles
Cars cost too much.
Im gonna try the t5 loom from a VN.
Goes into the loom under the dash.
Buying a manual ECU off The1 with tune.
I have the floor plate and pedal box.
Keep forgetting the clutch cable!
Thanks for the reply guys!
Vs hsv manta
41
Mackay
Vs hsv manta
Bell housing
pedal assembly
clutch cable ( t5 uses a cable clutch)
the plastic bit on centre consol
The gear box mount and the cross member it bolts to
All the bolts that are needed
Wombles
Cars cost too much.
Bell housing is on trans already.
Pedal box - check
Clutch cable - on order
Centre console insert - check.
Ill order the fly wheel bolts and gearbox mount.
304runner
( .Y. )
41
Central Coast NSW
Just spend the extra coin on a new HD clutch...
Nothing worse then doing all the above and finding out you cant get the maximum power to the treads because of a flogged out clutch.
The fun will start all over again...
Wombles
Cars cost too much.
Got a brand new clutch. Just a standard for the 5.0
