VS Acclaim Wagon Reverse Lights not working
djvass
1996 VS BT1 SS 5ltr original
HI All,
Just picked up a vs wagon and after going over a few things for th RWC the rear reverse lights arnt working. Did the basic stuff and checked the globs, they seemed good but i changed them anyway. Still no good, so i checked the fuse with a test light and it was good. So then i got the test light on the wires to the reverse lights and there is no power there. Where does it get its signal from? What else can i check?
Thanks
brocknjess
vs
is it a manual? ,mine had the same issue, ended up being the reverse light switch in the gear box
VS_Pete
Donating Member
djvass
mine is an auto. Where is the switch located?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Read the post above from VS_Pete_1 again as he's included the how to which gives everything you need to know.:thumbsup:
djvass
thanks for that i over looked it.
