VS air duct selector
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vs-bt1, Mar 12, 2012.
  1. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    idle didnt change, but now my brake lights dont work?? couldnt possibly be a related issue but WTF?? glad it didnt happen till after the roadworthy!!:hmmm:
  2. yxyx64
    yxyx64 New Member
    nsw
    Kia turbo + Holden badge, Chev badge in Texas
    gotta love women........both bulbs maybe ?? but more likely pedal switch or fuse
  3. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    not globes or fuse, lights do operate very rarely, may be switch.. have no idea how to test. auto electrician i think :(
  4. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    use a multimeter to test resistance with the peddle both in or out
  5. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    Where would I test resistance? Across the switch? I'm not familiar with the use of multimeters but I'll give it a go. Gonna try the test light first till I can get my hands on a metre
  6. aussie4life11
    Western Australia
    yea across the switch. make sure resistance isnt to high when its pressed in
  7. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    sorry to be so noobish when it comes to testing, but do i jam a prong either side of the switch, or does the black one have to go to an earth?:unsure:
  8. aussie4life11
    Western Australia
    either way. the only time you have to worry about the way the prongs are is for testing volts. as you arent testing how much power is getting thru it wont matter. use the lowest setting on the ohm section.
  9. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    :embarrass disconnect the battery first?
  10. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    ok so i got a reading of around 12.5 on the 20k setting, depress the pedal and it drops to 0, my line of thinkin suggests that zero resistance with the pedal pushed in means the switch is working......
  11. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    so by process of elimination, switch fuse and globes are ok, therefore i must have a bad earth....
  12. aussie4life11
    Western Australia
    hi resistance with peddle out is normal. sounds like you have a dodgie earth or a break in the line. use the volts setting and test on both sides of the switch with the ignition on. and both in released and depressed peddle.
  13. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    Will do, thanks for your help so far
  14. aussie4life11
    Western Australia
    no worries. if you get the same power on either side of the switch then its further down the line
  15. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    constant power on one side. the other side was intermittent. push the pedal in, get power. push it in again, no power. tried quite a few times and got no voltage on that side of the switch a LOT more times than i got voltage.
    so now im thinking switch again, a bad earth further down the line wouldnt show up at the switch would it
  16. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    replaced switch, problem solved, thanks again aussie4life11 :lock:
  17. aussie4life11
    Western Australia
    no worries mate. simple to track the problem and replace. i just bought $10 from ripco last week. i think every one should have a multimeter in their toolbox
  18. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    absolutely, i hate to think how much an auto elec could have stung me!
  19. aussie4life11
    Western Australia
    i think the word you were looking for is raped me lol. they are a ripoff usually. specially if you can fix it with a multimeter and 30 dollar switch
  20. vs-bt1
    vs-bt1 New Member
    mt gambier
    vs executive bt1 v8
    Switch was only 10 bucks from a local autoparts shop. Wouldn't have even attempted it if it hadn't been for this forum and it members.
