VS auto, no gears
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by teribul, Dec 27, 2006.
  1. teribul
    teribul New Member
    VS V6 Exec.
    I cannot select gears in my VS V6 auto (124.000Ks). At first the change from first to second became laboured and sluggish. This coincided with an occassional vibrating noise. About a week later smoke poured from under the bonnet as the fluid was spat out the filler tube over the exhaust manifold and left an oil trail to home. The fluid level is still ok, so must have been overfull I guess. Does anyone have any clues?
  2. dmitch
    dmitch DonkeySS
    Perth W.A
    VS SS S2
    prob nearly time 4 a rebuild...
  3. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    It is a bit unusual to have a tranny crapped itself at 124,000K's
    I mean my car has done 219,000k's and still on original tranny!!!
    Do you drive hard?? May be try and get it serviced see if that helps and chuck in a tranny cooler while you're at it.
    Do simply things first before you spend big $$.
    It might be simple as replacing the gear solenoids.
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Certainly sounds like a full overhaul is the next step. You should take it to a reputable auto specialist who will drive the vehicle, maybe drop the pan and give a report....but from your description it don't sound good. Figure on spending just under $2000 unfortunately or get a 2nd hand one. But I hope it ain't so. Good Luck.
  5. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    if you need a new gearbox speak to sircruisealot he got one for $1400 all built up with a shiftkit a lot better than 2k
  6. immortality
    Sth Auck, NZ
    sounds like a pretty serious failure and time for a rebuild. possibly a pump failure.
  7. teribul
    teribul New Member
    VS V6 Exec.
    Thanks anyway folks. Looks like a trip to the auto specialist eh!
  8. KingDiamond
    KingDiamond New Member
    Central Coast
    VR S Ute Manual
    Lol, you mean one of those blokes who said I needed a new gearbox, so a week later I serviced it and its sweet as.
