vs auto problems
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Ward78, Oct 11, 2012.
  1. Ward78
    Ward78 New Member
    Eatons Hill
    Vs berlina
    Hi I have a 96 berlina 4 speed auto I took on a run from Brisbane to Gladstone yesterday now today when I went to drive it it seems like 1st and 4th gears are not working. It's stuggles off the mark don't think it's slipping it don't rev right out only to about 3000 rpm then once it's going it seems ok but is still reving higher then normal ( about the same as if it is still in 3r). Can anyone out there please help with what the problem might be
  2. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    the 4th gear is torque converter lockup, as for 1st gear issue, put it in 1st gear manual and see if it changes to 2nd gear to know for sure.
    Is your oil level correct?
  3. VR38
    VR38 Well-Known Member
    VB SL/E
    Sounds like it is in LHM (limp home mode) Is the check engine light lit on the dash?
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
  5. Ward78
    Ward78 New Member
    Eatons Hill
    Vs berlina
    tried to do the code check but didn't work is this done the same way for the berlina with a trip computer???????????????
  6. VR38
    VB SL/E
  7. Ward78
    Ward78 New Member
    Eatons Hill
    Vs berlina
    Tried the way it says in that link but the engine light doesn't come on is this the way to do it with the trip computer as mine has one
  8. VR38
    VB SL/E
    Does the light come on when you switch the ignition on?
  9. Ward78
    Ward78 New Member
    Eatons Hill
    Vs berlina
    no the light dosen't come on at all is it ment to come on when you first start the car?? also it goes like normal in the gears that are left still revs out all the way and changes up the gear like normal. starting to get worried i'm going to be up for a new box:-(
  10. The1
    QLD
    VS V6 Berlina Auto
    with the key set to on it should show the light, sounds like bulb is blown.
  11. Ward78
    Ward78 New Member
    Eatons Hill
    Vs berlina
    Are they hard to get out and replace
  12. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    You should get hold of a Gregorys manual for your car as it will explain how to change the bulbs although a search on this may or may not give results. If you do decide to change the bulb (if it is missing) then do not turn ignition on whilst dash is removed otherwise you will set a lot of errors/codes. Bulbs rarely burn out.
