vs auto transmission fit s1 to s2
statesman_man
Sydney Australia
1995 Stateman
Does anyone know if a series 2 transmission will fit a series 1 without the need to change the computer etc..?
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
yes it will
Does anyone know if a series 2 transmission will fit a series 1 without the need to change the computer etc..?[/QUOTE s1 and s2 flexplates (what theyre called in auto's flywheels for manual) are different but its not really an issue as auto is driven off the torque convertor which bolts to your flywheel.
both boxes are same hydraulic so no wiring differences or
justbad4you
IF YOR NOT A HOLDEN
yes it will fit
Brett_jjj
Tamworth NSW
vs commodore
As long as the transmissions both have 13 pins in their electrical connectors, they will fit the VS.The VR models had the same 4L60E auto transmission,and it will bolt straight up to a VS,but the electrical connector on the VR only has 12 pins,not 13 like the VS,so it wont run properly. This is where it gets confusing.But as I said,just make sure they both have 13 pins in their connectors and they will be fine in the VS.
