Dropjeslover
**** happens
- Jan 20, 2013
- 15
- 0
- 0
- Location
- Emerald
- VS V6 Executive
Hi guys,
I've bought a nice VS wagon (V6 automatic, 260k km on the clock) about 2 months ago and now she's giving me problems.
After a 1100km drive without problems, I suddenly have a gearbox problem.
When cold, driving a few meters off in reverse and drive, sometimes I had to put the pedal down quite a bit (say, 4000rpm) to get it going. Problems disappeared after a few 100m tho. After a 30km drive, I suddenly saw some smoke coming up under the bonnet, and traced that back to a small oil spill from the transmission filler tube, the locked filler cap was pushed out.
I found and downloaded the workshop manual, found that it could have something to do with the oil level.
Checked the oil, maximum of the dipstick hot when warm and a bit over the cold mark. Thus I replaced the gearbox oil and filter, to fill her up to the right level.
Not too many problems on the mechanical part, but I first filled chucked in all the new oil (4L, I know it needs 4,8L, was getting some extra if needed) and then poured all the old oil in the new oils cannister. According to the marks on the cannister, only 2,5L came out. Huh?
Anyways, the more weird part is that when checking the oil levels again.
When the engine is cold, the dipstick says the level is way over the cold mark (nearly the hot mark).
When the engine is warm (warming it up ideling, no racing, gone through all gears), the oil barely touches the dipstick (one drop at the bottom, below the cold mark).
Took her for a test drive, no problems. Took her for a drive a day later and felt the problem in getting her going again (no problems after a few 100m).
One small side note, a few weeks before the 1100km trip I replaced the radiator due to a small leak in the water circuit, with one from the salvage yard. It seemed clean enough, but didn't really check or cleaned the transmission cooling part in it. No problems whatsoever during the trip, no smoke, no troubles driving off, etc.
Any ideas/tips/fixes?
Especially the "more oil when cold" is puzzeling me.
