Cupo
Serious issues with my car lately. Driving home about a month a go and it stalled 4 times in the space of 15 minutes. Managed to just start each time I rolled to the side and got it going.
So it'll start if it's cold, but if it's been running for about 15 minutes, it won't start back up. It will crank and sound totally awful, but it refuses to start. I drove it for about 20 minutes a week ago and it ran totally fine. But it's unreliable. I can't have it dying on me to and from work.
Things I've replaced and ruled out:
Coils and DFI Module, battery, oil filter, air filter and air flow sensor, fuel filter. It's got relatively (18 month old) spark plugs and leads, and I've tried new fuses and relays.
Still getting problems.
I've checked the codes and it's showing no errors other than Code 82 - 1 - 2 Shift Control Solenoid Fault - Auto Transmission Only. This code has been there for years. Mechanic said it's a transmission thing and not to worry unless the car starts playing up. But I really can't see how this is related to my problem.
I've even done the water on the crank angle sensor when it won't start (even though I'm not getting a code for a bad CAS) and that still didn't help it.
I've cleaned the IAC, throttle body, and plenum chamber too. Checked nearly every connection I could and gave them all a clean.
I'm running out of ideas here and feel that if I take it to a mechanic, they're just going to plug a scan tool in, see it's got no errors, start it up once (and it'll start) then collect the cash from me and I'll still be having dramas.
Any help from you guys would be super appreciated at this point.
Cheers.
Cheers.
