Vs Berlina/calais L3 Cluster
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by struggo, Oct 31, 2006.
  1. struggo
    struggo Member
    Old Sydney Town
    2016 VFII SSV Redline + 2013 FG MKII G6ET
    Hi All,
    I have a L3 cluster on my Berlina V6 and was hoping somebody could advise me what the Flow calcution setting is for on the trip computer. There is no mention of it in the owners/Holden manual. :bang:
    Mine is currently at 675. What is correct setting?
    Struggo
  2. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    From memory all three options should be set at 625 for the standard V6 auto.
  3. Jamie_87
    Jamie_87 New Member
    2003 BA XR6
    how do check the flow rate in trip computer? stupid question but is that the fel flow its measuring?
  4. struggo
    struggo Member
    Old Sydney Town
    HOLD THE SET BUTTON FOR ABOUT 5 SECONDS. Whilst holding the set button down you can change the settings using the up & down button.
  5. Jamie_87
    Jamie_87 New Member
    2003 BA XR6
    just went and tried and it just says fuel in middle window with 42.8(must be how much fuel in my tank) then it says calc ad has zero???
  6. struggo
    struggo Member
    Old Sydney Town
    Well then. I haven't seen that yet. I'm just getting the 3 numbers.
  7. Jamie_87
    Jamie_87 New Member
    2003 BA XR6
    weird , ahh well maybe comp is different in s1 and s2's
  8. Harvs82
    Glen Waverley VIC
    Nah guys, you are missing a small point here.
    The 42.8 is indeed the litres of fuel that are left in the fuel tank. The Cal bit in this window refers to the fuel tank size, which you can manually calibrate if you want, I believe it determines when the low fuel light comes on etc.
    Press the MODE button and then hold SET down again, and you will see the other information. Press the MODE button once more, and then hold SET down again, and you will see the third bit of information.
    Each 'set' of trip information shows different sets of calibration numbers, that being one set when you have the average speed, average fuel usage and odometer showing, one for when you have the trip time, fuel used and trip distance figures showing, and then a final set when you have the overspeed, instantaneous fuel usage and distance to empty figures displayed normally.
  9. Fekason
    Fekason Fekason
    Penrith NSW
    Default Settings
    The default calibration settings are 625 for distance, 625 for fuel flow and +0.00 for fuel quantity.
    These are generally very close unless you have non-standard wheeels/tyres or axle ratio.
    They can also be accurately set by following the calibration process that has been placed on this forum before. Do a search.
    If you cannot find it, send me a PM and I will provide a copy of the calibration insructions.
