VS Berlina II climate control and reverse lights
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by BOOST666, Jun 20, 2012.
  1. BOOST666
    BOOST666 Classic not plastic
    NSW Central Coast
    '79 VB SL/E 253, VY SS II
    Hi guys,
    Im having some issues and electrical diagnosis isn't my strong point.
    1. A week ago my digital climate control unit **** itself, a decent puff of smoke from the dash, pulled the unit apart and there is a fried capacitor.
    I got a second hand unit from the wreckers, rigged it up but no go, the buttons light up but it wont turn on, I have no power from any pin in
    the top plug that goes in the back, which I am assuming is to power the lcd etc. I cant find a climate control fuse.
    2. Reverse lights wont work, keeps blowing the fuse, I know its a short somewhere I really cant be bothered finding it so im asking you guys,
    maybe its a common problem and easy fix... im hoping so, any help will be much appreciated.
  2. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    did you check all the fuses or just the one that says thermo control? use a test light or DMM to test all the fuses in the pannel. failing that, just remove them all one by one. if you had a blown capacitor, the chances of there being a blown fuse is very high. when a capacitor blows its due to an overload of power or it incorrectly dischargine as it is basically just a battery.
  3. BOOST666
    NSW Central Coast
    Yes I used a test light and multimeter on all fuses under the dash, the only one not working is my reverse/canister purge fuse.
    Im going to test the relays today and that module in the dash near the stereo.
