vs bonnet?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by lumina01, Jan 16, 2007.
  1. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    ute reversed up my mates bonnet, fukt it nicely.
    wondering if anyone can tell me how 2 take the bonnet off and put the new 1 on? taking the strut things off n stuff? probly b easy but havent looked in2 it?
    cheers
  2. hakhawk
    the struts have little clips u pull away from the strut, then pull the strut off the ball.
    then unbolt the hinges from the bonnet. then lift.
    use 2 people to do it.
  3. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    ah yeh..will give it a crack this weekend.
    also the strut bar bent in half and stabbed the radiator, obiviously his getting a new radiator but does he need a new strut bar? or can we take that 1 off and hammer it straight again?
  4. hakhawk
    id be getting another one, itll probably end up leaking and goto ****.
  5. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    huh? what will leak?
    also what about that heat stuff on the top inside of the bonnet, new one doesnt have it, peel it off? stick it on the new bonnet with what? thanks mate
  6. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    If the car is a VS then you will probably be getting a secondhand bonnet with the heat stuff under the bonnet. The strut thing you talk about - is that the bit that has the bonnet release mechanism in it? - if so then the alignment of that item is critical as it determines the exact location of each mudguard.
  7. hakhawk
    sorry, i thought you meant the gas struts that hold it up.
    athe heat stuff you dont have to worry about putting back on, its not needed, you can if you want though.
  8. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    You could be right about the gas struts!!! - if they break at the mudguard end they can shoot forward and puncture the radiator.:)
  9. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    nah the bar that bent was the bar infront of the radiator thats meant to protect it. the things that hold it up are fine.
  10. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    Thanks people got it done today.
    Wrecked the pin that goes in at the front of the bonnet that holds down the thing that makes it lock/unlock (while taking it off the old bonnet), but just put a screw in with acouple of nuts on the end and she works fine.
