vs brake discs onto vp???
lowvpcal
croydon, vic
E2 Maloo R8 #0422, Grange 255 ls1 #0036 & #0167
gday yall
i have front and rear brake calipers from a vs 215i senator (twin piston corvette ones) im ready to put them on my car but im not sure about the discs. the calipers also came on the vn group a.
im not sure what discs i should be getting because the vs had 328x28mm front discs and 280x20 rears i think and vn group a had 330mm with the same caliper, i think lol
basically my question is will the vs spec 328x28mm and 280x20mm fit with no problems onto my vp v6? i also have a vp v8 master cylinder (1" i would assume) will that fit onto my v6 booster and aid the bigger calipers?
pow3rslave
DoNothing Member
eastern subs, vic
VP 5.0L
Not sure about the discs, but for the booster, i'd be putting on the the booster and MC.
lowvpcal
croydon, vic
bugger thats alot of figging around ah well
Immortality
Staff member
Sth Auck, NZ
the VR/VSmodels use a different front brake rotor design then the VB-VP commodores. the callipers should fit but you would need to use proper VN GRP A rotors to suit or use VT style conversion hubs to use the VS style rotors. the rears should bolt on but i'm not 100% certain on that
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Hoppers do a conversion to the later style hubs that take the slip on rotors. Highly recommended as those VN Group A rotors cost a heap.
Reaper
lowvpcal
croydon, vic
thanks reaper ill have a look at that on the week end
gslrallysport
VZ AWD One Tonner
They're not that bad... a pair of slotted rotors is $289. There's ALOT worse in the HSV range of rotor than that.
lowvpcal
croydon, vic
thats pretty good! is that front or rears? is it only the front that will need the hub conversion?
ryan21
89 vn calais v6
you will want to do the v8 mc and booster i did the vn v8 brake upgrade and just changed the mc it was like pushing against a brick wall until i changed to the v8 booster.
lowvpcal
croydon, vic
thanks ryan
is it just the front hubs that need to be changed??
