VS Calais Front Fan
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Sara Pax, Jun 1, 2008.
  1. Sara Pax
    Sara Pax Banned
    1994 VR Wagon and 2007 6 litre Calais V
    Should a VS Calais V6 have the front Electric Fan that sits in front of the Air Con Condensor.
    My VR V6 has one
    This car doesnt overheat
  2. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    No, it should be sitting behind the radiator. I don't see how calais get different setup than other lower end models in the VS range.
    Your previous VR got a buick V6 engine which has slightly different fan setup than the VS's which got the Ecotec engines.
    Someone correct me if I'm wrong. This is what I think.
  3. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The auxiliary electric fan ahead of the airconditioning condenser was only used for the VR V6 and for VR/VS V8 models. The VS V6 had a two speed fan behind the radiator which replaced the need or an auxiliary fan.
  4. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    Correct. Whenever the air conditioning compressor clutch is activated ie you have the air con running, the radiator cooling fan will operate. The fan will also operate when the coolant temperature sensor detects the need for it. Generally you will only hear it run on the lower speed, which is pretty noisy anyway, but on warmer days, especially with the a/c running, you will hear it go up a notch to the high speed, which is very loud and throws copious amounts of hot air out from underneath the car.
