VS Calais Front Suspension Noise
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Sara Pax, Oct 1, 2008.
  1. Sara Pax
    Sara Pax Banned
    1994 VR Wagon and 2007 6 litre Calais V
    Hello all,
    My VS Series II Calais is making some strange noising from the front end.
    It only does it after about 50 kms of driving
    Its sort of a clicking sound from the LHS
    I have been under the car and cant see anything wrong
    My thoughs are that the LHS Front Shock internal valving might be crook and when it heats up it starts clicking
    Any other Ideas
    Thanks
  2. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    I was about to post with a similar issue.
    My VS Ute has started making a very loud creaking/clunking/knocking ratchetting sound that really feels like somthing in the steering/suspension.
    It won't make the noise when it is cold but as soon as it has driven a bit (warm days are worse) the noise starts every time I go over a bump and/or around a corner.
    My mechanic has been over the entire suspension and said that all of the bushes are intact - his opinion is that a bush is loosening up once it gets warm...but he claims not to have heard it when he took it for a test drive (that's cos the bloody thing was cold!)
    To me it sounds and feels (through the steering and through the floor) exactly like the stabiliser bar tie end bushes, which I have had to replace twice since I got the thing lowered - which was only about two years ago so the shocks should still be good (right?).
    I have stopped using nolathene bushes on the sway bar tie ends and gone back to rubber - this seems to at least stop them disintegrating so quickly but this noise is attrocious.
    It makes most of the noise when the suspension is extending i.e. when going over a hole, cornering or taking off from the lights (maybe a bit quickly).
    When I brake hard I am convinced I can feel movement somewhere in the system - it feels like everything except the wheels keep going forward for another 10 or 20 millimetres; as well as this I am convinced (this could be psychosomatic) that it starts to oversteer once it warms up.
    I would be grateful for any advice about this issue, or failing that maybe a recommendation for a decent suspension technician on the Brisbane Northside; I don't want to take it back to a mechanic who says he can't hear what is obviously a significant noise.
    Cheers.
  3. greenacc
    greenacc Searching for the billion
    VE Berlina
    Struma, going by your perfect description it sounds like you have got worn Radius rod bushes. the other bushes in your front suspension are probably flogged out too.
  4. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    The other thing to check would be your front wheel hubs. Jack up the front and try and move the wheel with one hand on the top and one on the bottom. If you can feel significant play or a clunking noise then that's your problem.
  5. Rhino Racing
    Rhino Racing New Member
    vn/vp Speedway Street Sedan
    I had a top strut bearing make this clicking noise just as you described. Was left hand side too. Dunno why it wasnt there when it was cold... but changing the top bearing only fixed the problem.
    It is a simple fix, i hope that is all you have to do.
    Good luck.
  6. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    Thanks for the tip - sorry about the delay getting back about this one...mongreal car just got back from the workshop AGAIN...3rd time in 6 weeks...first the radiator, then the heater tap and now the harmonic balancer.
    I took every opportunity to hassle the mechanic about the noises (even straight out mentioned radius rod bushes this time) and he keeps telling me that he has checked all of the bushes and they are all good - problem is that he is too busy to get right into it...which is why I am looking for a specialist in this sort of thing (and maybe another mechanic)...the challenge here is that if you find someone who has the time you have to ask yourself why isn't he busy? I'm still happy for any recommendations though - especailly for a small shop or someone just starting out on their own.
    Cheers.
  7. rcnugget
    rcnugget New Member
    VX S2 Exec
    ive heard some batches of nolathane bushes make strange noises and this is normal, not that I have ever had this problem but may be something to look out for
  8. Sara Pax
    Sara Pax Banned
    Well stuff me rotten
    I spent 3 days pulling apart the front end
    Replacing the Struts, strut tops and bearings
    Only to go for a drive and the noise was worse
    More investigation revealed that the noise was from the Steering Rack tie rod at the rack end
    The ball joint was dry and making all the noises
    I greased it a bit and the noise went away
    So now its going for 2 new tie rods and a wheel alignment
    What a ****er
  9. GAMBLR
    GAMBLR More trouble than u think
    Whyalla (yawn), South Australia
    '04 VZ Calais LS1
    also having these noises, albeit for different reasons...
    firstly, i spoke to a suspension place, who told me the swaybar links and the rubbers that go with them are prone to deteriorating on the VN onward models, especially if the front suspension has been pulled out. often makes clunking noises and clinking noises like a chain dragging. i got quoted $150 fitted and installed a new swaybar link kit from Nolethane.
    secondly, if the suspension is clunking around a bit, it may pay to check the strut top mounts and bearings. when doing mine for the first time, we lost 2 or 3 ball bearings from the case, and i didnt think too much of it. then after travelling through the hills, i found the shaft of the strut had torn away the inners of the mount, and was poking up under the bonnet. figures those bearings are more important than what i thought... steering feels heavier and creaks a fair bit, especially at slow speeds.
    sigh, and i thought all i needed was springs and a wheel alignment lol
  10. Sara Pax
    Sara Pax Banned
    After all the exploring around the front end i gave up and bought 2 new struts, 2 new strut tops, and 2 new bearings
    Spent a few days in the stinking heat installing all this gear
    Then i went for a drive and the Flucking noise was worse
    So i did more investigation and found out the original noise was the flamin tie rod ball joint at the rack end on the left side
    It was drier than a Nuns nasty
    Sprayed some grease at it and now the noise is gone
    Wouldnt that rip the crutch out of ya night dress
    OH well at least the front end is new now
    Just have to get the tie rods replaced
  11. darthdingas
    darthdingas DDC
    Mount Isa
    VR S2 Commodore remote turbo
    I have the same prob with a Vr s2, i have replaced everthing in the front end steering rack, struts springs bushes, bearings, But my noise is more pronounced when turning, i also hear it like Struma does on a hard launch, i have suparoo Radius rod bushes three months old after sara pax post im going to buy new tie rod end today, but a little sus on that, well work for her cant hurt to try
    any other advice would be sweet
