Vs calais radiator question please thanks.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by CONNOR, Jan 6, 2013.
  1. CONNOR
    CONNOR New Member
    allover
    vs
    The car does not over heat - nor has the radiator lost water / dropped in water...
    Issue is i just noticed the overflow bottle is empty could this be more to do with the heat??.. in general (weather being so hot)?..
    I have no water leaks no water in the oil...
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Is it a 6 or 8. If it's a 6 the inlet manifold gaskets are renowned for having issues. Fill up the over flow again and monitor it.
  3. CONNOR
    CONNOR New Member
    allover
    vs
    Its a 6 but wouldnt it be milky and wouldnt the radiator be empty? or lower than normal?...
    in my case as i said its just the radiator (overflow) bottle thats empty - would it be from the outside temperature bieng so hot (evaporating)..
  4. wraith
    Demonicaland
    The plastic would insulate it pretty well from the temperature. The symptoms sometimes don't appear.
  5. immortality
    Sth Auck, NZ
    Fill the overflow bottle to the full cold mark and monitor the level. As the engine heats the radiator cap will allow a small amount of coolant into the overflow to maintain the correct cooling system pressure. Once the engine is shut down and cools, coolant is drawn back into the coolant system past radiator cap. You will need to monitor the overflow tank level over a period of time. Thinks like intake manifold gaskets that are starting to fail will only loose a very small amount of coolant at any time. Small amounts of coolant in the oil won't go milky, rather as the oil heats to operating temperature the coolant is actually boiled off and burnt in the combustion process through the PCV system.
  6. K-BAGZ
    K-BAGZ De Plane! De Plane!
    Far North QLD
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    Have you pressure tested the cooling system and radiator cap? Would be good to know.
  7. CONNOR
    CONNOR New Member
    allover
    vs
    It has had all new gaskets radiator - hoses the lot.
    Thats why i am not sure as to why its just the overflow bottle loosing water... and not the radiator.
  8. K-BAGZ
    Far North QLD
    I'd still pressure test the system and cap. Coolant could be weeping into the combustion chamber through the head gasket or a cylinder bore.
  9. CONNOR
    CONNOR New Member
    allover
    vs
    Yes i do understand what you are saying...
    But wouldnt the radiator itself , be lower than normal ??...
    if there was a gasket leak or a weep anywhere?.
  10. K-BAGZ
    Far North QLD
    Maybe your cooling system isn't making enough pressure to unseat the relief valve and allowing the coolant back to the overflow bottle.
    With the engine cold, preferably in the morning before driving, fill the overflow and radiator and check both levels again the next morning.
    What pressure rating is the radiator cap?
  11. CONNOR
    CONNOR New Member
    allover
    vs
    Well being , its a complete system , from hoses to radiator to cap all from holden i would only think , its all standard....
    But as i said , could it be evaparating , as it has never done it before , and the radiator itself has not lost water......
  12. K-BAGZ
    Far North QLD
    The coolant would have to be bingo boiling hot for it to just 'disappear'.
    So every time you check the overflow bottle, it's empty. Correct?
  13. CONNOR
    CONNOR New Member
    allover
    vs
    no its been over a 6 mth period thats what im asking ,
    does it ever need to be topped up (occasionally)? or is something you simply fill and walk away and only replace on your next change over in the complete system
  14. K-BAGZ
    Far North QLD
    The cooling system arrangement on the Commodores is setup so you don't have to regularly check it.
    That's what the overflow bottle is there for, a reservoir for extra coolant when required for the radiator and engine block.
